F-20 motor problems
Posted by Jeff on December 15, 2002 at 19:40:39 from (216.138.40.64):
hey i have just bought and F-20 that is all there but is locked up really really bad. the crank and cam is shot. i got another motor that has new bearings and a good crank and good cam. 2 of the sleeves have busted already trying to get them out. is there anyways to not ruin the sleeves but still get them out easy and reuse them? is there anyother engine on a farmall tractor that may have to same size piston and sleeves. and can you buy just sleeves and not pistons?
Post A Followup
: Re: F-20 motor problems
