Re: Can an M Farmall lift an 800 lb 3pt disc?
Posted by RB on December 15, 2002 at 20:14:28 from (64.12.97.13):
In Reply to: Can an M Farmall lift an 800 lb 3pt disc? posted by aaron on December 15, 2002 at 17:35:21:
I use a 3 point mounted 8 ft Rhino shredder (weighs 1600 lb) on my SMTA. I put four 100lb weights on the front of the tractor. The tractor also has a wide front. It handles the weight of the shredder ok, but could use a little more weight up front. Also, I have moved 5X6' round bales with a rear mounted 3 point bale spear. It really needs the front weights for this job. I have to rev up the engine for enough hydrolic power to lift both the shredder and big round hay bales.
Post A Followup
: Re: Re: Can an M Farmall lift an 800 lb 3pt disc?
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
