Re: unhooking/removing hyd pump
Posted by Steven@nd on December 16, 2002 at 18:59:16 from (12.23.184.205):
In Reply to: unhooking/removing hyd pump posted by Dave on December 16, 2002 at 18:08:56:
I would guess that the distributor pumps rob at least 5 hp from the engine.
To remove the pump, be sure engine is at TDC of number 1 cylinder and remove distributor first. Remove pipes from pump and plug them, then remove the 4 bolts that hold the pump in and take it off. You will need the distributor drive from an M or W-6 to replace the pump. You might also have to change the front cover to the old style too, but I'm not sure on that.
Post A Followup
: Re: Re: unhooking/removing hyd pump
