Re: H Battery problems
Posted by Diesel Don on December 18, 2002 at 14:35:55 from (206.40.118.114):
In Reply to: H Battery problems posted by Kenny K on December 18, 2002 at 14:14:47:
Check the ground wire and the wire from battery to starter for corrosion and/or loose connections.Check the starter switch for worn/burned contacts.Most of the problems with 6v systems will be found right here.I am assuming the generator is operating correctly.
Post A Followup
: Re: Re: H Battery problems
