Re: Farmall Super H Won't Charge
Posted by Bob M on December 19, 2002 at 10:29:22 from (165.170.128.66):
In Reply to: Farmall Super H Won't Charge posted by Farmer Dan on December 18, 2002 at 19:30:14:
Dan - Here's a few things to try in order: 1 - Check first the obvious - make sure the wiring is properly connected and all terminals tight. Make sure also the regulator is solidly grounded (mounting plate is clean and the screws are tight) 2 - With the engine off, turn on the ignition switch and look at the ammeter. It should show 3 or 4 amps discharge. If it shows a few amps CHARGE the ammeter hooked up backward (swap the wires on the two ammeter posts), or you have the system ground reversed. If it indicates 0, the ammeter itself is bad, or the ammeter is wired up wrong. 3 - Polarize the generator: With the motor still off briefly connect the BAT and GEN terminals at the regulator with a short jumper wire. Soon as you get a spark you've successfully polarized. 4 - Now start the tractor and run at about 1/2 speed. If the ammeter shows a few amps of charge, you are all set. If it shows discharge: 5 - Temporarily jumper the BAT and GEN terminals at the regulator while observing the ammeter. If it now shows charge, replace the regulator. If it still shows discharge: 6 - Temporarily connect the regulator FLD terminal to a good ground while observing the ammeter. If it now shows charge, again replace the regulator. If it still shows discharge the problem is in the generator. Unless you have experience with generators, suggest taking it to a starter shop for a checkup. ...Bob M PS - I too own a '53 Super H - great tractor!!
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
