Re: Need help on H carberator rebuild
Posted by RC Sprenger on December 19, 2002 at 17:43:00 from (4.42.198.60):
In Reply to: Need help on H carberator rebuild posted by KURT on December 18, 2002 at 14:15:43:
Kurt,
Know exactly which pc you are talking about. This is the push point for the fuel reserve float bowl. You first have to split the carb.You will then see float bowl on right side, facing carb as if you had it on tractor. Once you have the float bowl removed you will see the recess that this three sided piece fits down into.
Hope this helps with your carb rebuild.
Post A Followup
: Re: Re: Need help on H carberator rebuild
