Re: Farmall A vs Super A Hydraulic Lift
Posted by Hugh MacKay on December 20, 2002 at 02:32:41 from (216.208.58.153):
In Reply to: Farmall A vs Super A Hydraulic Lift posted by Mark from Genoa on December 19, 2002 at 19:34:53:
I don't have equipment for posting pictures. The difference however is; The torque tube on the A is round whereas the SA torque tube has a flat top with 4 holes for bolting down hydraulic unit. The flat surface is for the unit to set on. Also hydraulic pump on SA mounts just under the distributor and is driven by timeing and cam shaft gears. The A is not drilled for mounting the pump or for the shaft.
Post A Followup
: Re: Re: Farmall A vs Super A Hydraulic Lift
