Re: replacement rims for 36 inch round spoke F+H wheels
Posted by Bus Driver on December 20, 2002 at 07:01:16 from (65.165.153.76):
In Reply to: replacement rims for 36 inch round spoke F+H wheels posted by J on December 19, 2002 at 18:52:07:
I sure hope that there will be some creative suggestions. I have one plan, but would like to have others from which to choose. I have not done this, but the procedure I have worked out would use a rim from a Super C. Remove the mounting clips, cut the center and narrow the rim to the desired width. Measure carefully the inside diameter of the rim. Make a jig and use a large trammel to mark the F&H wheel at that diameter. Cut the F&H wheel at the markings- probably a plasma cutter with a plywood circle as a guide would be best. Slip the modified C rim over the F&H wheel and weld in place- a MIG welder probably would be the neatest way. Other bad places on the F&H wheel should be patched and ground to shape before welding the C rim in place. This repair is a lot of labor.
Post A Followup
: Re: Re: replacement rims for 36 inch round spoke F+H wheels
