Re: farmall correct tire size
Posted by Bill Smith on December 20, 2002 at 11:17:06 from (63.147.130.7):
In Reply to: farmall correct tire size posted by David Schumacher on December 20, 2002 at 07:06:30:
About all the H's I have seen have had 38" tires on the rear. Although, it seems I have heard tell of 36" tires and rims for an H on this sight. Not sure if it was an option or just what somebody came up with on a cut down steel wheel project. But I would say the 38" rears are way more common for the H. The F-20's had 36" tires on the rear. And the M's I believe had like 38" rims but took a wider, bigger tire than the H. As long as tire width matches up pretty close to rim width tires will work fine. A wider tire and a narrow rim will probably work ok but won't look right and vise versa. Just keep tire sizes close to rim sizes.
Post A Followup
: Re: Re: farmall correct tire size
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
