Re: engine type
Posted by gene b on December 21, 2002 at 01:48:36 from (63.25.166.28):
In Reply to: engine type posted by twopop on December 20, 2002 at 18:11:40:
Mine is a 113 but the block has a place for 1. fuel pump, 2.place for hy pump, 3.the starter goes below the filter and points toward the driver so the starter runs backwards from one on a tractor. and 4.a dipstick to check oil. Have seen these engines on an A and B they used the tractor starter as the bellhousings were for starters. One even had the C hy pump on and made a neat three point on a B.
Post A Followup
: Re: Re: engine type
