Re: stuck hydrolics on 3-point
Posted by The Undertaker on December 21, 2002 at 05:09:42 from (64.40.66.92):
In Reply to: stuck hydrolics on 3-point posted by Mark Calderone on December 20, 2002 at 20:26:26:
Mark!
If you're shoving snow around, then the temperature must be below freezing, huh? Compressed lubricants moving at venturi speeds may form an ice blockage in the lines somewhere, if slightest moisture present. If you haven't parked it inside to thaw, then give that a try?
"TU"
Post A Followup
: Re: Re: stuck hydrolics on 3-point
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
