Re: more power for farmall M
Posted by Michael Soldan on December 21, 2002 at 13:23:22 from (216.46.130.25):
In Reply to: more power for farmall M posted by chris on December 21, 2002 at 10:19:44:
Chris, I am not a puller but I've been around the block a few times and there are some small things you can do to get a little more kick out of an M. First traction is a function of pressure and so chose a tire that gives you the best numbers in term of pounds per square inch on the ground, a narrower tire will give better traction than a wide one because the weight per square inch is greater,but if you go too small you reverse the situation. The M needs a tuned exhaust and the factory muffler usually was close but you can learn from the drag racers. Take a length of exhaust pipe than fits the M starting with 4 feet at least. Work the M and put it through it's paces. Observe the pipe and where the pipe appears burned purple \blue is the place to cut it off. The pipe is now tuned to the system and will give you the best back pressure/flow and it will scavenge. Scavenging is hard to describe but it has the right back pressure using unburned gas to create more horsepower within the head. I would also use an octane boost to give your fuel a little extra kick. There is some disagreement as to octane not all being used but it works at the drag strip.Other than tires this costs nothing to try. Also the oil breather/ cleaner can be emptied of oil for the pulls and/or replaced with a paper element to give good flow. Good luck from Mike in exeter Ontario
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
