Re: Re: electrical question
Posted by Doug in OR on December 21, 2002 at 14:44:56 from (12.225.51.197):
In Reply to: Re: electrical question posted by Bigdog on December 19, 2002 at 20:39:00:
This above reply pretty much hits it on the head. Be aware that you need to change from a positive ground to a negative ground if you install an alternator. It is also a good idea to change the ammeter over to a voltmeter. If you keep the ammeter and change from positive ground to negative ground, you should reverse all the connections at the ammeter. While not really necessary, the ammeter will read backwards if you don't make this change.
Post A Followup
: Re: Re: Re: electrical question
