Farmall Tractors Discussion Board
Re: Super M Electrical Problems
Posted by The Red on August 30, 1999 at 07:31:12 from (206.246.187.2):
In Reply to: Super M Electrical Problems posted by Greg on August 30, 1999 at 05:41:52:
Greg if I understand you correctly you left the coil switch on. Try another coil. It almost sounds like it shorted if the switch is smoking for no reason. Also check your coil wire to make sure it isn't shorting against the frame somewhere. That is a cheap fix.
Post a Followup
: Re: Re: Super M Electrical Problems
