Re: Valve Adjustment On Farmall H
Posted by CNKS on December 21, 2002 at 19:44:50 from (207.178.96.214):
In Reply to: Valve Adjustment On Farmall H posted by H- Man on December 21, 2002 at 18:48:29:
Easiest to adjust by following firing order. Use hand crank to put each cylinder TDC on the compression stroke. .017 is for adjustment hot. If you are reinstalling after a valve job, etc, add a couple of thousands for the cold adjustment, and readjust hot after it has run awhile. May need to do it more than once. Can't answer your other question. Lot more info in the archives.
Post A Followup
: Re: Re: Valve Adjustment On Farmall H
