Re: Farmall 140 carb problem
Posted by Hugh MacKay on December 22, 2002 at 04:05:01 from (216.208.58.131):
In Reply to: Farmall 140 carb problem posted by Gerald on December 21, 2002 at 19:47:40:
Your problem is probably dirt, water or stale gas, and maybe all three. I have 3 of these tractors and over years have run into all; the dirt, the water and the stale gas. Carb, tank and lines all need cleaning. when you put it back together have screen in sediment bowl and add an inline filter between there and carb.
These tractors have less problem when worked every day. I use to use these tractors commercially and rarely ever had a problem. Problem when only used ocasionally, if you leave them full of gas it goes stale. If you leave them empty rust flakes form on inside of tank, as well as condensation. I once didn't start my SA for 6 months, was full of gas, Screen in sediment bowl was completely sealed with shelac. I have left them with little gas in them and bingo the problem is water. I now get mine out every two weeks and just take them for a drive. These old tractors are much like ourselves, they need exercise. And we thought they were a big change from the horse.
Post A Followup
: Re: Re: Farmall 140 carb problem
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
