Re: more power for farmall M
Posted by Farmall Boy on December 22, 2002 at 15:16:54 from (206.228.247.224):
In Reply to: more power for farmall M posted by chris on December 21, 2002 at 10:19:44:
In the governor casing there are 2 set screws. pull the throttle back and see wich 1 will give u more throttle i am pretty sure it is the bottom one(the other one would give u higher idle)screw it out till u get the desired rpms (ours is all the way out and we hav no probs). U SHOULD POST THIS ON THE PULLING BOARD. if you have the hp the wider is usually the better and older tired are sharper and harder and almost always pull better
Post A Followup
: Re: Re: more power for farmall M
