Re: 49 Farmall M Ignition system
Posted by Bob M on December 24, 2002 at 08:16:47 from (24.169.120.229):
In Reply to: 49 Farmall M Ignition system posted by Jeff Pirkey on December 24, 2002 at 08:00:47:
Jeff - First check to see if you are getting spark out of the coil. Pull the hot wire from the center of the distributor, attach it to a spark plug and lay the plug top of the coil. Then turn on the ignition and open the points by hand. If you get a hot spark at the plug, somehow your distributor has gotten out of time. If not the above, perhaps your new coil is a so-called "12 volt" coil? If yes, a ballast resistor is unnecessary. Including it in the circuit will drop the primary current too low to give a decent spark. Try bypassing the resistor and see if you get a spark. If you do, and the primary current (measured with the engine off) is less than about 4 amps, simply get rid the ballast resistor. If not the above, other possibilities are a bad (or poorly grounded) condensor or a bad coil. Good luck!
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
