Re: Re: Re: Re: Re: Farmall 140 coil.
Posted by Bob M on December 26, 2002 at 11:50:54 from (24.169.120.229):
In Reply to: Re: Re: Re: Re: Farmall 140 coil. posted by Hugh MacKay on December 26, 2002 at 08:13:50:
Hugh - The same pull rod style starter switch is used on all later Farmall tractors - and on other brands of tractors too. I think those plastic shields are provided inside the switch to prevent shorting of the movable contact bar as the switch wears...but I'm not certain. One thing is certain however: If the starter switch develops an internal short, the whole switch can heat up red hot in a manner of a few seconds after connecting the battery (been there, done that!)
BTW a new switch is cheap (I got one a few weeks ago for <$10 at my local alternator shop). My recommendation would be to simply replace yours with a new one! ...Bob M
Post A Followup
: Re: Re: Re: Re: Re: Re: Farmall 140 coil.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
