Re: Bad Super M
Posted by DOUG on December 26, 2002 at 15:52:38 from (208.1.87.67):
In Reply to: Bad Super M posted by Scott on December 26, 2002 at 13:56:06:
Scott sounds like you have the gear shift lever in wrong, could be in two gears at one time. take it out off gear and roll it and see if your input shaft is turning, if so you have it in gear when it is nutral. you will have to have to pull your gear shift lever out and line up your forks. Just a idea. Hope this helps Doug
Post A Followup
: Re: Re: Bad Super M
