FARMALL H gas leak
Posted by Don LC on December 28, 2002 at 22:30:16 from (24.166.248.35):
I have a high speed gas fitting/boul leak...fitting turns too hard.....could be cross threaded, but looks OK.....the needle adjustment turns too hard also....can I re-tap the boul and install new fitting and needle?...What is the tap size?....can I seal this fitting with LOCK TIGHT? .... where do I get these two parts?......how did you stop yours from leaking? ....Thanks Don
Post A Followup
: Re: FARMALL H gas leak
