Re: h model water pump
Posted by The Red on December 29, 2002 at 10:26:32 from (12.84.241.202):
In Reply to: h model water pump posted by Brian on December 29, 2002 at 10:15:50:
Grease zerks just grease the hub bearings. After you drain the coolant, you will have to remove the fan blades. You will find a large nut that you unscrew. There is packing under that nut. You can probably add 1 layer of new packing material and replace the nut and fan blades and stop your leaking. Tighten the nut down tight. You might have to add 2 layers or dig out the old and replace.
Post A Followup
: Re: Re: h model water pump
