Re: Re: Re: voltage regulator- cut out question
Posted by Bob M on December 29, 2002 at 19:20:31 from (24.169.120.229):
In Reply to: Re: Re: voltage regulator- cut out question posted by dave in Mn on December 29, 2002 at 17:58:42:
Dave - You are correct - the cutout (or voltage regulator) won't work unless it is grounded. Additionally with a cutout, for the generator to work the headlight switch must be in working condition and the ammeter box securely grounded.
Also you polarize a cut-out same as a voltage regulator: Momentarily jumper the BAT and GEN terminals with the battery connected and the motor stopped.
Good luck!!
Post A Followup
: Re: Re: Re: Re: voltage regulator- cut out question
