Re: Stuck head on W-9
Posted by MNBill on December 30, 2002 at 06:54:29 from (206.10.38.128):
In Reply to: Stuck head on W-9 posted by Steven@nd on December 30, 2002 at 06:46:03:
Steven,
I had the same problem with my Super H last summer. I ended up keeping tension on the head with a chain hoist, penetrating oil on the head bolts and using a 4X4 block of wood and a sledge hammer to slooowly tap the head off of the stud bolts. It took about 2 1/2 hours to get it off.
Post A Followup
: Re: Re: Stuck head on W-9
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
