Re: Stuck head on W-9
Posted by Steven@nd got it! on December 30, 2002 at 09:12:52 from (12.23.184.79):
In Reply to: Stuck head on W-9 posted by Steven@nd on December 30, 2002 at 06:46:03:
Got it off! Just decided to come off today evidently. Went out and tapped a little more with a chisel and it moved.
Head is cracked on #3 combustion chamber and goes to a water jacket hole. Hopefully the machine shop can pin it for me.
Post A Followup
: Re: Re: Stuck head on W-9
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
