Re: transmission flush B Farmall
Posted by Steven@nd on December 30, 2002 at 11:56:29 from (12.23.184.79):
In Reply to: transmission flush B Farmall posted by David in Missouri on December 30, 2002 at 09:51:29:
Another thing about Hy-Tran is that when you push the clutch, the gears will run forever and you always have to grind into gear.
I run 85W-140 in my H and it slips into gear right away with no grinding. The SMTA on the other hand runs forever after pushing the clutch. Yes, the TA and clutch are adjusted properly.
Post A Followup
: Re: Re: transmission flush B Farmall
