Re: Farmall M Leaks
Posted by The Red on December 30, 2002 at 14:37:53 from (12.84.238.112):
In Reply to: Farmall M Leaks posted by Elkhorn Denny on December 30, 2002 at 14:18:01:
Elkhorn you will not have to split the tractor. The liftall belly pump assembly can be removed. More than likely the gasket between the pump assembly and the reservoir case is leaking along with the countershaft drive seal. With the liftall pump out, there is enough room to replace the main driveshaft seal and countershaft seal. They get to leaking with age. You will also want to order new gaskets for the two retainer assemblies that those 2 seals are in. I have done several Hs but have not tackled my 2 Ms. Those two are on my 2003 list of things to do.
Post A Followup
: Re: Re: Farmall M Leaks
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
