Re: 300 PTO shut off under belly
Posted by Hugh MacKay on December 30, 2002 at 16:44:56 from (209.226.247.97):
In Reply to: 300 PTO shut off under belly posted by Pete on December 30, 2002 at 05:06:14:
It is called a seasonal disconnect. In the days when 300 was new there were not a lot of pto chores during winter months. If the weather is cold, below 0 F, 300 will start much easier with that disconnected. When my 300 was new I used to disconnect pto at night, start tractor in am, warm it up, then shut tractor down and connect pto if I were going to use it that day.
Deere had a system in 60-70s one lever disconnected pto, hydraulics and power shift while starting in cold weather. Soon as engine was warmed up you engaged lever again.
Both the IH and Deere systems were great in cold climates, saved a lot of battery and starter problems.
Post A Followup
: Re: Re: 300 PTO shut off under belly
Today's Featured Article - Product Review: Kreem Brand Fuel Tank Liner - by Staff. This condition has occurred on a few machines that we have had and fortunately we were able to borrow the technique used at the local motorcycle shop. The product that we have used is called Kreem thouh there are others on the market, this one was recommended and available. This particular product is sold in three parts, a bottle of etch, dryer, and sealer. We were fortunate enough to start the process with stern warnings from those that had used this type of product before. The horror ... [Read Article]
