Re: Retrofitting power lift on F-12
Posted by F14 on December 30, 2002 at 20:14:04 from (216.204.135.248):
In Reply to: Retrofitting power lift on F-12 posted by Stevie on December 30, 2002 at 11:53:29:
Is it 'correct'? I dunno.
Can it be done? Absolutely. I took a Power Lift off a parts tractor and put it on my non-power lift F14. Only tricky part is getting the preload, which consists of shims behind the pump mount on the gearshaft that drives it, correct. The rest is a bolt on. You'll want to take the top cover off before unbolting the bearing carrier and replacing it with the pump housing. There's mounting studs, a collar they screw into and shims on the back side of the transmission casing that you'll want to be able to keep track of.
Post A Followup
: Re: Re: Retrofitting power lift on F-12
