Re: Re: Dead 1566
Posted by RPM on December 31, 2002 at 07:21:26 from (63.110.182.225):
In Reply to: Re: Dead 1566 posted by Fred on December 30, 2002 at 17:29:16:
Reading yours and the others posts, I can suspect Hytran or filter, this is only common item between your problem, the tractor has a MCV pump and a rear frame pump, 2 systems and you are having a problem with both, if splines are bad they will usually make a terrific screeching noise, the Hytran and filter must be clean, if its dirty or contaminated it will damage both systems pumps. Refill at least 20 gallons new Hytran and filter, on filter cover put in a new oring, might have a suction leak. 15 series have a problem in rear frame with bearings failing, might have a lot of fine metal in Hytran.
Post A Followup
: Re: Re: Re: Dead 1566
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
