Farmall Tractors Discussion Board
Re: Super A vs 100
Posted by Raymond (54 SA) on August 31, 1999 at 09:14:23 from (209.176.153.105):
In Reply to: Super A vs 100 posted by Enus on August 30, 1999 at 15:44:02:
Here are the ratings I found for each tractor...........
100
The Farmall 100 tractor was made from 1954 to 1956 by International Harvester.
The tractor came with a 123 cid 4 cylinder engine and weighed approximately
2,600 lbs. It had an offset engine and a wide front end just like the Farmall
Super A.
Drawbar.......... 15 hp
Belt Pulley....... 18 hp
Maximum Pull. 2503 lbs.
Bore & Stroke. 3 1/8 x 4
Rated RPM..... 1400
Gears.............. 4 forward 1 reverse
Basic Weight... 3038 lbs.
Test Weight..... 3688
Front Tires....... 5.00 x 15
Rear Tires........ 11 x 24
Super A
The Farmall Super A tractor was made from 1947 to 1954 by International
Harvester. It is rated as a 16in one bottom plow tractor with a 113 cid 4
cylinder engine and weighed approximately 2,385 lbs. It had an offset engine and
a wide front end.
Drawbar.......... 17 hp
Belt Pulley....... 19 hp
Maximum Pull. N/A
Bore & Stroke. 3 x 4
Rated RPM..... 1400
Basic Weight... 2385 lbs.
Test Weight..... N/A
Front Tires....... 4.00 x 15
Rear Tires........ 9 x 24
Post a Followup
: Re: Re: Super A vs 100
