Re: Using Plastic Gauge
Posted by Bill Smith on December 31, 2002 at 12:26:39 from (63.147.130.95):
In Reply to: Using Plastic Gauge posted by Brian on December 31, 2002 at 11:56:31:
You only use a peice one time. I never did put a peice clear around the bearing. Is what I did is this. Without oiling or prelubing bearing, put dry bearing in dry bearing caps. Place a piece of plasti guage (instead of going around, go the other way) front to back on the crank or bearing. Just one peice and you have to put it on in the matter that it doesn't get smashed by weight of parts (gravity) in the assembling process. Placing a piece of plasti guage and then putting entire weight of crank on top of it won't be accurate in other words. Do crank shaft main bearings only, and first. Assemble and use torque specs. Then disassemble and compare the plastiguage to chart. If it is proper clearance then prelube bearings and reassemble. Remove plasti guage and the bearings have to stay in the same cap as tested in. Then you can do rod bearings in the same nature one at a time. With engine out and upside down, I do all mains at the same time. If in tractor I torque all main caps to spec and then do the plasti guage check one bearing at a time with the other caps torqued during the entire process.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
