Re: Super A wiring harness
Posted by Steve - IN on December 31, 2002 at 13:15:38 from (12.222.17.160):
In Reply to: Super A wiring harness posted by patpeery on December 31, 2002 at 11:23:25:
pat,
The standard setup is for 6 volts, which is thicker, fatter gauge than needed for 12 volt systems. If you've gone to a one wire Delco SI alternator you might have a spare wire dangling, and if you've gone to a remote voltage regulator insead of one mounted on a 12 v generator, you may need some extra wire -- but otherwise should be no problem.
Steve
Post A Followup
: Re: Re: Super A wiring harness
