Re: i'm confused!
Posted by Dan on January 02, 2003 at 07:11:54 from (12.104.69.193):
In Reply to: i'm confused! posted by Bryce Andreasen on January 01, 2003 at 20:55:03:
I have converted 2 different tractors and put new 12 volt coil with resister on one and used a chrysler type resister on the other. Both worked equally well. I used an alternator on both, bought used from a wrecking yard. Have never regretted changing over though some of the guys say stay with 6 volts and tune up the system. I'm not a purist and I use one of the tractors daily to feed with in cold weather. The 12 volt conversion worked well for me. On my SMTA I used the original generator bracket turned upside down to mount the alternator. and used the chrysler type resister. I had the starter redone to use a ford type solenoid instead of the pull rod and I run the wire around the resister for starting.
Post A Followup
: Re: Re: i'm confused!
