Re: cam gear on farmall h
Posted by eric on January 02, 2003 at 15:44:25 from (152.163.189.203):
In Reply to: cam gear on farmall h posted by ERIC TEMPLETON on January 01, 2003 at 16:56:00:
i have the head off everything looks good but like i said i pulled the cam gear off and it has some wear and the plate behind it had some wear the nut on the gear was tight but when i pulled the gear off and pulled the cam out flush with the block then it worked fine thanks im going to check on a new gear and plate thanks
Post A Followup
: Re: Re: cam gear on farmall h
