Re: converting 350 to 12 volt
Posted by steve on January 02, 2003 at 18:41:30 from (204.246.222.51):
In Reply to: converting 350 to 12 volt posted by Adam on January 02, 2003 at 17:36:55:
i am assumiong you went from 6 volt positive ground to 12 volt negative ground. lets also assume you have a amp meater and not a volt meter. in that case the amp meter will read backward. you need to swtich all the wires from one terminal to the other and vice versa.---in the end the alternator power cable should go to one side of the amp meter, and the other side goes to the battery. the lights and accessories wire should be on the alternator side so the gague will read a draw when the lights are on. the starter should be on the other side between the battery and ampmeter. you will not see a drop (much) on the gauge when the starter is cranking.
Post A Followup
: Re: Re: converting 350 to 12 volt
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
