Re: Drawbar for A Cultivision
Posted by Farmer Bob on January 02, 2003 at 20:30:24 from (67.3.10.164):
In Reply to: Drawbar for A Cultivision posted by Farmall Jack on January 02, 2003 at 16:14:41:
I've attached a pic of the drawbar on my '45 A. It also has the swinging drawbar and mounting bar. As for the front crank pulley, you have to remove the front end of the tractor along with radiator. Make sure you chock the rear wheels and crib up plenty of blocking under the flywheel housing so the tractor is stable. Do not use cement blocks for shoring material. Remove any possible capscrew and/or washer that could be screwed into the front end of the crankshaft to hold the old pulley on. Using a three-jaw puller, place heavy steel plates behind the crank pulley for the jaws of the puller to pull against thus spreading out the force. Center the shaft of the puller in the hole in the end of the crankshaft. Tighten up the puller and make sure everything is lined up right. You may need some heat on the outside of the pulley housing heat and tighten, heat and tighten. you may also need to carefully give the end of the puller tightener bolt a good whack with a deadblow hammer setting up some viabration. Lay several layers of cardboard on the floor under the pulley because when it lets go it could come out of the puller and land hard. Don't be in any hurry to pick it up if you have applied heat to the pulley.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
