Farmall Tractors Discussion Board
Re: Fluid in front tires for H
Posted by Phil Auten on August 31, 1999 at 11:34:00 from (206.175.72.226):
In Reply to: Fluid in front tires for H posted by Joe on August 30, 1999 at 20:06:38:
Joe,
I think the others are correct about not bothering with fluid in the front tires. Unless your H already has a 3-point hitch you will be stuck with a pull type mower or a belly mower. A good running H should handle either of these in up to 6 foot width in all but the heaviest conditions. Then you would have to stop everything and shift into first gear, but you could mow nearly anything then. The pull type mower will probably be the cheapest way to go and easiest to hitch up and remove so other implements can be used.
Enjoy,
Phil
Post a Followup
: Re: Re: Fluid in front tires for H
