Re: generator question
Posted by Bob M on January 03, 2003 at 19:05:17 from (24.169.120.229):
In Reply to: generator question posted by Geoff on January 03, 2003 at 17:12:32:
Interesting question... Presuming the 6 volt armature will fit mechanically into the 12 volt generator frame, the voltage the combination will deliver should be determined by which regulator you use (either 6 volt or 12 volts). But that's just my "educated" guess - I've never tried something like this!
Post A Followup
: Re: Re: generator question
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
