Re: Piston Wrist Pins For W-30
Posted by JerePa on January 03, 2003 at 19:53:17 from (66.109.255.220):
In Reply to: Piston Wrist Pins For W-30 posted by DLP on January 03, 2003 at 16:09:25:
If you can get a catalog that gives pin diameters, you could get one that is the diameter you need providing the wall thickness is adequate & wind up having to cut the length down. Motor shops could help you with that also. JerePa
Post A Followup
: Re: Re: Piston Wrist Pins For W-30
