Re: milky hydraulic oil
Posted by Eugene on January 03, 2003 at 22:58:51 from (209.153.6.58):
In Reply to: milky hydraulic oil posted by Norm on January 03, 2003 at 15:23:06:
Are you sure it is water? Sounds like it could be air. I was told that hytran will turn water into a clump. If you drain a little into a cup and let it set if it is air it will clear up. IF it stays milky then your right, it is water.
Eugene
Post A Followup
: Re: Re: milky hydraulic oil
