Re: Farmall H water pump leaking
Posted by Nebraska Kirk on March 28, 2009 at 19:50:42 from (207.91.4.173):
In Reply to: Re: Farmall H water pump leaking posted by slydog on March 28, 2009 at 17:51:33:
Yes, you can remove the water pump without having to remove the radiator, I have done it on my M. You will have to take the fan off the pump and disconnect the radiator brace so that the top of the radiator can be pushed forward a little to give you enough clearance to get the pump out.
