Re: Carburetor Leaks
Posted by George Willer on January 05, 2003 at 08:42:57 from (66.242.44.44):
In Reply to: Carburetor Leaks posted by Steve on January 05, 2003 at 03:46:54:
Steve,
If the float needle valve seals (not difficult to assure) AND the hard gasket under the seat AND the hard gasket under the discharge nozzle do not leak (by no means certain), AND the float itself doesn't leak, you will have a drip-free carburetor. The needles are often blamed for the other problems.
This gasket defect was found as the reason several of my worst carburetors were dripping by testing with low pressure air and soap bubbles. Now that I know that, I'm fixing my problem carburetors one by one.
You can too!
George Willer
Post A Followup
: Re: Re: Carburetor Leaks
