Re: Re: Farmall H bull pinion shaft oil seals
Posted by Dick on January 05, 2003 at 12:26:56 from (172.129.97.48):
In Reply to: Re: Farmall H bull pinion shaft oil seals posted by The Red on January 05, 2003 at 09:32:22:
Thanks!
I tried the two holes as you suggested. I wasn't able to get it loose with the chisel driven sideways, but the holes did weaken it and make it much easier to cut out with a chisel.
Post A Followup
: Re: Re: Re: Farmall H bull pinion shaft oil seals
