Re: Carburetor Leaks
Posted by Chuck on January 05, 2003 at 12:56:24 from (216.170.58.10):
In Reply to: Carburetor Leaks posted by Steve on January 05, 2003 at 03:46:54:
H carbureters have a float about one half the size of M carbureters however they both use the same size neetle and seat therfore by adjusting both the H and M floats to specification there is about one half the force exerted on the H neetle to close it as there is on the M neetle.I have by lowering the float level on H carbs a little it puts more pressure on the neetle to form a tighter seal.Be sure and check the float to be sure it is not partialy collapsed as that will greatly effect the sealing pressure.George is right about the leaking gaskets.Good luck.
Post A Followup
: Re: Re: Carburetor Leaks
