Which direction does a fell press out the rear pto shaft oil seal on an M Farmall?
Posted by aaron on January 06, 2003 at 16:46:36 from (130.20.144.81):
I am assuming a fella has to go to a machine shop to press out the old pto shaft seal? There are apparently two lodged in my housing and they will not come out. Which way do they pull out? With the housing on can you pull them out or must you take off the housing and press them to the inside?
Post A Followup
: Re: Which direction does a fell press out the rear pto shaft oil seal on an M Farmall?
