Re: 1206 diesel engine
Posted by IHBRAD on January 06, 2003 at 17:48:27 from (64.12.97.13):
In Reply to: 1206 diesel engine posted by twopop on January 06, 2003 at 17:10:10:
8 degrees BTDC. You have to open up the cover on the right side of the bell housing. Line 8 degrees BTDC to the pointer under the cover. Take the little cover off the side of your injection pump.You will probably have to loosen up the two 3/8's nut and turn the pump until the two little lines inside of that window match together. A 1206 will have only a Roosamaster (now Stanadyne) pump on it unless,someone put an RD pump on after the factory.
Post A Followup
: Re: Re: 1206 diesel engine
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
