Re: international 674 wont start or stop
Posted by Gordon on January 06, 2003 at 18:14:58 from (169.207.175.124):
In Reply to: international 674 wont start or stop posted by Matt Danhauer on January 06, 2003 at 14:49:31:
Check the timeing and check to see if the spark plugs are to hot. If they are not to hot I still would try colder ones.Chech if the engine is running lean a gasket could do that also.
Post A Followup
: Re: Re: international 674 wont start or stop
