Re: M live Hydraulic power unit
Posted by Steven@nd on January 08, 2003 at 19:38:22 from (12.15.56.136):
In Reply to: M live Hydraulic power unit posted by Brad kimball on January 08, 2003 at 19:20:01:
First off, being it was bought at a farm auction and they don't know if it works, assume that it doesn't work.
It fits between the distributor and the timing cover and is driven from the timing gears. You will need to modify the belly pump reservoir to make it work with this pump or add another reservoir. Also you will need a 2-way valve and hoses. Expect to have over $200 in the hoses, valve, and reservoir by the time your done.
Post A Followup
: Re: Re: M live Hydraulic power unit
