Re: Re: Re: Anyone put a hydraulic pump inline with crankshaft?
Posted by D Webber on January 09, 2003 at 05:46:06 from (216.106.40.187):
In Reply to: Re: Re: Anyone put a hydraulic pump inline with crankshaft? posted by Pete on January 08, 2003 at 15:26:34:
Pete
I used a roll pin also . If you had the engine crank , make it like the end of it plus the extra that you add to go in the crank center hole . You have to mount the pump tight or the shaft will have the tendency to jump out like a hand crank does . It does work well though The pump came off a combine , I think it just lifted the head so it's only about 1100 g/p/s, but plenty big enough for a Super A If I remember you must add about 3/8 of an inch for the centering hole on the crank and taper it so it fits tight.
Post A Followup
: Re: Re: Re: Re: Anyone put a hydraulic pump inline with crankshaft?
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
